I use the Lucas stop leak fluid in mine. It is way thicker. Under normal driving conditions I get almost no leaking, when off roading it will lose some fluid if I get the steering bound up in the rocks. From a conversation I had in Moab it is the fitting on the hose that seperates and leaks...as I am sure most of you have seen.
