Uh I seem to remember getting mine from amazon or rockauto for $50 I think, but those hoses are legit, wouldn't be surprised if it just needs a new pump and brass washers on there.
I completely forgot about Rockauto!
Edelmann hose with 12 month warranty: $33
Gates hose with lifetime warranty: $46
Thanks!!
Originally Posted by Triathlete
I use the Lucas stop leak fluid in mine. It is way thicker. Under normal driving conditions I get almost no leaking, when off roading it will lose some fluid if I get the steering bound up in the rocks. From a conversation I had in Moab it is the fitting on the hose that seperates and leaks...as I am sure most of you have seen.
The mechanic I talked to kinda mentioned this under his breath. I'm inclined to try this first. Thanks!
