Results 1 to 13 of 13
Thread: Tranny shifter button ie. not shifting from P
    Apr 2003
    1999 Astral Silver 1222
    Hey!
    I think I "accidentally" verified it is the gate on the brake pedal.
    1. I went to brake for a red light using cruise control with a car in front of me. AHHHHH!!!! the cruise control didnt want to disengage. Luckily, I reached over and hit the main cruise button on the dash in time.
    2. This morning, I was doing the usual fiddling with the tranny lock out button, and I leaned my body to the right for a better grip with a tired hand, and VOILA! my foot on the brake pressed the pedal laterally to the left while it was depressed. Click! the button depressed.
    3. After a morning stop for coffee, I did the same thing and used the lateral left pressure. Click! Shifted just fine.
    Now I just have to figure out how to get under there and adjust it. At least I have a backup plan now until the weekend gets here.
    Thanks mdwyer, you were right about the gate!!!
    FYI - you may not have brake lights either if the switch isn't engaging (assume it's all on the same circuit).
    2001 Proton VX #0690
    Quote Originally Posted by MrCrowley View Post
    Damn, I love being right. You might give the search engine an attempt. Sticky shift gates seem to be a pretty common problem, and I'm almost positive I've seen it discussed before. If I come across it, I'll come back with a link.
    Apr 2003
    Yeah, but I was ***-uming the center console area and the button, and was unaware of a "gate" until you mentioned it, so my search was futile early on. Also, this morning I had to laterally press the brake to the right, so I am thinking that maybe the gate is loose, or something else has developed some play. Luckily, the brake lights seem to function ok.
    Thanks for the help!!!
    Aug 2005
    1999, silver, 0887
    Ask Tone Monday about this he knows alot this problem. It's not unique.
  1. vx is shifting badly
    By stu in forum VX Troubleshooting...
    Last Post: 07/05/2006, 03:27 PM
  2. outline of tranny filter on tranny pan......
    Last Post: 05/16/2006, 07:44 PM
  3. Replies: 8
    Last Post: 05/29/2004, 02:12 PM
  4. shifting gears?
    By Bagheera in forum VX Talk...
    Last Post: 12/12/2003, 09:10 PM
  5. Help... Switching from mechanical tranny to fluid tranny???
    By ScubaSteve in forum VX Troubleshooting...
    Last Post: 10/03/2003, 02:41 AM
