Originally Posted by
Triathlete
4. The indy kit is complete...comes with all you need. Roward just used this kit a week ago.
Yep, the kit comes with grease, lub for the cone, metal straps, and the cone and 4 boots. (didn't use the cone since I completely remove the shaft and disassembled end to properly clean it) , All in all, a real PITA, but you will save a bunch of money doing it yourself.
The one trick I did learn that I didn't see mentioned anywhere was on the inner boot. Secure the small end AFTER you have secured the big end to the inner green cup. Why, it gives you the ability to burp the boot by slipping a small flat tip screwdriver under it and removing any deformity of the boot. I did find that the boots were a bit too long and had to extend it past the grove on the axle shaft so it didn't chaff on the metal band. Billy mentioned that he heard others had to do that too. There were no instructions with the kit, but you can find many 'how to' on the net including a mecatech vid. Have fun
