Autozone sells Spectra radiators, O'reillys sells Murray, online reviews, Spectra is terrible, and fail, going for the Murray instead
Do you know for sure that fluid is "blowing" out of your radiator, or are you just going by where the fluid that's leaking is ending up on your floor? Maybe the leak is on the passenger side of the vehicle, but it's running along something like your radiator support before it's finding a hole to fall out of and onto the floor.
If there was a hole in your radiator, it wouldn't stop leaking just because you shut off the engine.
