That means the trans cooler is leaking. It is part of the radiator. The radiator is pretty easy to replace. 2 coolant hoses, 2 trans lines and 4 mount bolts. Refil fluids. Make sure to plug the trans lines to keep from loosing to much fluid. I am sure others will have more tips to make it easier...
