Results 1 to 15 of 15
Thread: Filled up transmission, fluid poured outta drivers side radiator
    Astral Silver - 1131
    In and out are right beside each other. They are pretty exposed. They look innocent at first glance. As for mine I had to add a screw on clamp to the connections.
    Look under the passenger side of your rad. they are about the size of your little finger
    1999,silver,vehicross,1891
    radiator drivers side major leak
    my lines on the passenger side are good, I disconnect and drain those to get more old fluid out of intercooler when I service transmission, it was on the drivers side of the radiator that fluid came pouring out, is their a line in or out over there?
  1. drivers side cv axle removal
    By heavy d in forum Chit-Chat ...
    Last Post: 10/06/2016, 07:33 AM
  2. Drivers side front axle.
    By RodL in forum VX Talk...
    Last Post: 07/26/2013, 08:44 AM
  3. Drivers Side CV/Axle Assembly
    By ariastwin in forum VX Talk...
    Last Post: 11/26/2012, 04:36 AM
  4. Need a drivers side headlight!!!! HELP
    By Dumke in forum VX Troubleshooting...
    Last Post: 04/28/2008, 06:52 AM
  5. Transmission Fluid Filter Transfer Case Fluid Change
    Last Post: 09/16/2005, 02:23 PM
