Results 1 to 12 of 12
Thread: Fuel pump replace??
    Mar 2014
    2001, Yellow, 1336
    Fuel pump replace??
    Well, my VX stalled out a couple times then check engine light came on.. So made it to the mechanic and he told me it was do to low fuel pressure. having replaced a pump before I just picked one up along with the filter and got to work. BUT, I can't figure out how to get the dang cover off the tank. Seems that it hooks under the rear bumper some how. But I can't get the bumper off. Can anyone help?
    Mar 2006
    2001 FOXFIRE 0579
    you may want to talk to JoFotoz about that. He was talking last month about how big of a pain it was to drop the tank. Others have mentioned it would be easier to cut a hole in the floorboard above the tank. Im not going to say anything else in fear i may jinx myself and have to do the same. All that said, I will leave you with a "good luck"!
    Yea... its a real PITA!
    And I wasnt concerned with putting it back in ,
    as it was a crashed VX I was stripping.
    Rear cladding and rear 'impact bar' need removing in order to extract tank.
    And getting hands / tools in the confined spaces to disconnect fill hose, electrics, return and feed lines etc is gnarly.
    If I ever have to do fuel pump etc on the ORW....
    .....I'll cut the rear floor FOR SURE... and make a hatch.
    Sorry to be a downer about it..but thats my experience with this.
    Jo
    Mar 2014
    2001, Yellow, 1336
    You wouldn't happen to have instructions for that would you? I have found got all the screws out of the rear number but can't get it off.
    Sorry Tony...no "instructions" per se...
    ..I just kept taking bits apart!
    If its the rear cladding you are talking about..
    ...there are sneaky fasteners under the back edge
    of the side / rear cladding too.
    You need to release back portion of rear side cladding
    to get at them.
    Hope that helps.
    Jo
    2001, Ebony Black, 1153
    Look up the instructions for upgraded hitch installation. Tom4Bren should have it.
    Nov 2002
    Wrench
    It isn't a walk in the park but if you've got access to a Trooper Haynes manual that'll get you most of the way there. As Jo mentions you've got to fiddle with the cladding a bit but all in all it's a determined afternoon (and maybe early evening) job. I've dropped several Isuzu tanks so aren't as fazed by it as the first one so once it's over with you won't be so disinclined to tackle again. Just make sure to invest in a good quality fuel pump so you won't have to! I've had great success with the Bosch pumps and don't forget to put in a new sock. I also replace all the flexible fuel lines and clamps (don't skimp!) while I've the opportunity.
    Mar 2014
    2001, Yellow, 1336
    Thanks everyone
    I'll get back on it tomorrow.
    Nov 2012
    There's no 'I' in denial.
    Feb 2010
    1999 Ironman,#1-1767, #2-1326
    yea I cut the hole to replace it and then the tank was so bad had to drop it to replace the tank anyway so had to all the work after all.
    Nov 2007
    1999 Astral Silver
    that link doesnt work, I may be doing a fuel pump in mine soon...
    Check out our VX accessories @
    www.planetsvx.com
    click on the Vehicross button on the left side
    of the page
    Nov 2012
  1. Fuel pump inoperative
    By alleycat in forum VX Troubleshooting...
    Last Post: 09/27/2019, 09:17 AM
  2. Possible fuel pump failure?
    By logman in forum VX Troubleshooting...
    Last Post: 03/29/2017, 12:10 PM
  3. Help: How to Replace fuel lines going to the fuel rails.
  4. Fuel Pump Probs
    Last Post: 11/10/2004, 06:28 PM
