Well The fuel pump was the problem. All the wiring and connections were ok. Just a heads up, the wiring goes through the body on the passenger side under the seat. And there's a connector there you should check for any corrosion/bad contact. Also the fuel pump fuse is under the hood on the right side, it's a basic 15 amp fuse. Later all.
