Results 1 to 15 of 16
Thread: High idle question
    '99 Ebony Black VX, 0339
    Idle control valve is located on the throttle body and is held in by 2 small torx. Remove and clean opening and plunger with carb cleaner. George, glad you got it fixed but I think they did the shotgun approach replacing three sensors - can you look at the invoice and post the part numbers and descriptions?
    '99 silver (#1897)
    Sure Tone-
    (1) 8-17112-649-0...Idle Air Control ------$80.90
    (1) 8-17106-680-0...Sensor (no descrip)---$89.19
    (1) 8-15326-386-0...Sensor; Eng Co-------$34.85
    5550.................CPCI-----------------$249.20
    "Cause: Codes for TP,IAC,and Coolant Temp Sensor Malfunction"
    "74020 Codes for TP, IAC, Coolant Temp Sensor malfunction 2.80. Replaced sticking Idle Air Control Valve. Replaced Throttle Position Sensor due to having a internal short. Replaced the Coolant Temp Sensor for being out of range. Cleared the PCM of all codes and releared the Idle Control System due to replacing the IAC Valve".
    Parts=$227.59 (not incl oil change mat)
    Labor=$255.50
    ________
    Xxx Stream
  1. Intermittant High Idle (again)
    By Grif in forum VX Troubleshooting...
    Last Post: 10/30/2018, 05:55 AM
  2. High idle/ high power steering pressure?
    By Rene M in forum VX Troubleshooting...
    Last Post: 09/22/2007, 03:21 PM
  3. High start up idle
    Last Post: 04/14/2006, 02:55 PM
  4. High/Low Idle at start up
    By Ruflyf in forum VX Troubleshooting...
    Last Post: 03/19/2006, 06:20 AM
  5. RPM to high at idle
    By ThunderChicken in forum VX Troubleshooting...
    Last Post: 09/23/2004, 11:09 AM
