Results 1 to 5 of 5
Thread: Supercharger - Searching for an intake pipe.
    May 2016
    99 Trooper S Supercharged
    Hello everyone,
    Just recently acquired an Alpine supercharger and installed it on my 99 Trooper. Loving it for the most part. It's kinda noisy at idle but I am sure most of you know that already.
    Here is a picture of the beast.
    Anyway, it came with a cone air filter. I would like to convert this back to the stock filter box with some modification to allow more air in.
    The question I have for you guys is this. In the picture below there is a piece of intake pipe that has like a 45 degree bend at the TB. I am looking for this part. To me it looks like maybe its off a 3.2 SOHC - I see that a bunch of you VXers are using this setup.
    EDIT: Sorry I couldn't link the image. I will try to do it later but maybe some of you will know what I am talking about.
    Thank you!
    May 2016
    Here is the piece I am looking for. Am I correct that this is off a 3.2 SOHC?
    http://forum.planetisuzoo.com/downlo...e.php?id=30971
    I think most of us are using something aftermarket for the intake plumbing. I always found that the piece it came stock with got too hot from the engine and was not any real help for the passing of cool air being some alloy. I would try to avoid that stock piece if you want to push cooler air. Look C/F or even F/G if possible. Plastic should be ok as well. Of course the trick is, finding something aftermarket to work with the airbox. You will most likely have to do some modifications to a part. I believe my C/F intake was advertised for Acura/Hondas, and I cut/filed/modified the crap out of it to get it to work with the airbox. Of course, if you go with a simple short ram, it will be easier to find a lot of options. Just my opinion....
    In any case, maybe someone here with the S/C will be willing to sell you theirs. *shrug*
    Good luck!
    May 2016
    Thanks for the info. What is C/F and F/G?
    Carbon fiber - fiberglass.
  1. Supercharger and intake manifold gasket
    By ScottinMA in forum VX Modifications...
    Last Post: 01/08/2016, 08:20 AM
  2. Supercharger Cold Air Intake (CAI)
    Last Post: 11/24/2007, 05:52 PM
  3. New to the board and searching for a VX
    By hugabone in forum VX Talk...
    Last Post: 10/31/2005, 02:47 PM
  4. Searching for Allan - AKA BigMeatVX
    By MI VX in forum VX Talk...
    Last Post: 02/25/2004, 10:36 AM
  5. Searching for BETA testers...
    By JAG! in forum VX Talk...
    Last Post: 10/13/2003, 11:25 AM
