Results 1 to 4 of 4
Thread: Lean/rich gauge question
    May 2004
    99 Astral Silver w/ SC
    I was at Autozone the other day and noticed along with the typical oil pres., boost, volt gauges they had for sale there was also a lean/rich gauge. I was wondering if anyone has any experience with these and are they worth having? Also what would be involved in getting it hooked up working correctly?
    ----Trans Siberian Orchestra
    Arrow
    It'd look kool ...but without the ability to adjust the mixture (see engine management thread) it would be eye candy.(like my boost ga.)
    All fuel/air mix chores are handled by the ECU, I've heard, & I'm no expert...at best, I have a basic understanding of how all this stuph works.
    Maybe one of the more knowledgable members will chime in here.
    2001 Foxfire 1232
    Installation is easy, besides +12v and ground, you just tap into the signal wire from the O2 sensor.
    As far as practical value, would lean toward the "eye candy" comment. Any problem with a rich or lean fuel mixture that the gauge is likely to show would already have triggered a CEL.
    May 2004
    ok, thats what I was thinking too, but didnt know where it was drawing its info from. I figured if it actually did the readings itself, may be its worthwhile, but if its just displaying a different sensors reading, then I agree "eye candy."
    Although I do like my boost gauge "eye candy." I would have to take out either my volt meter, boost, or oil pres. to have room for it and unless it would serve a "real" purpose I cant see pulling one of the others.
  1. How to fix the lean condition CEL codes on a supercharged VX?
    By VehiGAZ in forum VX Troubleshooting...
    Last Post: 04/26/2013, 09:22 AM
  2. Running Rich! white exhaust during cold startup
    By Rampage108 in forum VX Troubleshooting...
    Last Post: 05/18/2012, 09:39 PM
  3. Code Reader - Lean System?
    By wekilled in forum VX Talk...
    Last Post: 01/27/2008, 12:46 AM
  4. wiring Air/Fuel Gauge question
    By VXtreme in forum VX Talk...
    Last Post: 03/10/2005, 10:04 AM
  5. Running Lean. Need Advice.
    By Cline in forum VX Troubleshooting...
    Last Post: 04/21/2004, 08:44 AM
