 Originally Posted by
PHO2GR4
				Hi Bart,
Well, after doing WAY too much research, I've finally decided that you made the right choice. The Teflon Chambers are the only Teflon-ish rims that will suit the 1999 VX. The others were either too big or had a WAY too different offset.
I'll probably stick some Yokohama Geolandar AT/S tires in a 265-70-16 size. Using the online tire calculator, the diameter difference is only 1.11 inches...or an estimated 30.61 inch total diameter.
I'll probably do a combination lift/cladding trim so the tires don't rub.
Eric
You might not even need to worry about a trim with the offset of these rims and that 30.6" tire size.  You definitely don't need a lift - but maybe crank on the torsion bars enough to remove the rake if you want. That combo will look good!
