Your rear seats should have the usual one-piece shoulder and lap belt. I believe one end attaches near the rear, behind the panels, it comes up in front of the side glass and hooks into a bolt near the roof where the winding mechanism hangs. Then it routes across the passenger to the center where it clicks in, and the other end routes across the passenger lap to a bolt in the floor. That's from memory so don't quote me.
I don't believe those anchor points in the rear were designed for attaching a car seat. If you want to use them for that purpose, or just for extra safety, I would suggest upgrading to grade 8 or better hardware. However, we do not have a mounting loop in the front, so you still cannot use the standard "LATCH" type attachment.
The correct way to attach a car seat in the VX is by using the full shoulder strap, leveling the seat correctly, and installing a metal clip to prevent the belt from slipping.
I also highly recommend buying Tone's 4.5" passenger seat extenders for ease of ingress and egress!
Sweet recaro kid seat, BTW!
How much did that set you back?
