I really need some help on this. I would like to flat tow [all four on the ground] a VX behind a motorhome.
Here is what I have found out, BlueOx.com makes a tow bar and base plate, Remco.com makes a drive shaft disconect for the 2001 VX. Remco says the 2001 VX has a 23 1/4 '' front drive shaft?,They say only the 2001 VX can be towed with there set up.
Can anyone tell me what the length of the front and rear drive shafts are on a 1999 and a 2000 VX, also need to know if anyone is flat towing a VX and if so what is your set-up?? THANKS!!
