Hi folks -
Well, my check engine light came on for the first time since I bought it in 2001.
Checked the code with my trusty scan guage and found the following code: P0402
According to OBD ll records, this indicates "EGR Excessive Flow Detected"
What can I do about this? Can it simply be removed and cleaned or do I need a new EGR?
I did a search here and only found one post regarding that code and it was simply a list of all the codes OBD ll can issue.
Anyone else experience this problem?
Symptoms:
Rough idel the past day or two, this morning while driving it seemed like it was gonna stall out on me while stopped but it never did. At speed, everything seems fine.
I did some research and found the following:
Causes
A code P0402 most likely means one or more of the following has happened:
* The DPFE (differential pressure) sensor is faulty and needs to be replaced
* There is a blockage in the EGR (most likely carbon buildup)
* The EGR valve is faulty
* The EGR valve may not be opening due to a lack of vaccuum
Possible Solutions
With a P0402, it is common for people to replace the EGR valve, only to have the problem return. The most likely solution is to replace the DPFE sensor.
* Check the voltage at the DPFE sensor both at idle and when the EGR is open
* Replace the DPFE sensor
Thanks for any assistance you can provide on this matter
