Results 1 to 15 of 17
Thread: My new Dash
    99 white ironman
    My new Dash
    sorry, I didn't get a chance to photoshop- just copy paste
    I installed the rancho control unit on the left and a vga touch screen on the right for my computer.. no more center air vents and still surviving in FL! This is my second attempt, and still not final. I went to a junkyard and pulled a dash bezel for 25 bucks. It’s all adhesives too and melted plastic, no fiber-glass or bondo..
    question though, does anyone know which wire to the stereo is the illumination one? I need to run it to the rancho gauges so I can see them at night without turning on the dome light. Thanks!
    Mar 2005
    01 Ebony - #0379
    WAY COOL!!
    I've been planning a dual-din mod to my dash for a while now. It looks awsome and clean, post some close up pics of trim around the screen, I'd like to see how you finished it. It sucks how everything is at weird angles on the center radio/vent console, it's not easy to work around.
    Cheers.
    Nov 2002
    Looks good Frank! Do you still have the PC armrest?
    there are two different wires that go to the illumination, not sure which is the 'correct' one but i used the solid orange wire and that makes my headunit dim with the lights
    1999. Unique Ironman
    Wow looks really nice and nice "TV" you have =) but no more center air vents looks like not usual but its still cool
    Aug 2003
    1999,Silver,Vehicross,0928
    was the dash brezel out of a vx?
    Sep 2003
    `99 Astral #1889 (sold) | `95 Trooper TeraLows-5.38s-35s | `98 Acura SLX
    NICE WORK!!!
    Quote Originally Posted by Francesco Rizzo
    …question though, does anyone know which wire to the stereo is the illumination one? I need to run it to the rancho gauges so I can see them at night without turning on the dome light. Thanks!
    When I mounted a Rancho Control Unit in the Rodeo…
    …in order to get the gauges to light-up with the rest of the dash, I simply connected them to the hot wire output on the back of the dimmer switch.
    Also, here’s a helpful tip to insure a long and happy relationship with your controller…
    If you haven't done so already, be sure to use Synthetic Bearing Grease on the O-rings inside of the knob chambers on the shocks, instead of the recommended Spray Lithium Grease – it seals them 10,000 times better!
    "This trail is so bumpy, it's knocking my bra straps off!" - Miss Kathy
    Sep 2003
    Quote Originally Posted by MZ-N10
    It could have been from a 1995.5 - 97 Rodeo... They share the same dash configuration.
    (...which really messes with my head sometimes when I’m switching from the VX to the Rodeo, or vice-versa )
    2001,Ebony,VehiCROSS,1092
    [QUOTE=Francesco Rizzo
    question though, does anyone know which wire to the stereo is the illumination one? I need to run it to the rancho gauges so I can see them at night without turning on the dome light. Thanks![/QUOTE]
    The red/grn wire from the back of the dash light dimmer switch would be the one to grab.
    Nice, how much did the touch screen run you and what is the exact name/brand of it? How does it interface with your laptop? Just through the VGA out port??? Does it also have a/v inputs?
    Thanks,
    PLEEEASE tell me where you got that dash bezel!!! I have a boost gauge that I've wanted to install in the fuzzy hole and YOU have discovered the piece of plastic I so desperately need.
    Scott
    I can't speak for FR but, I'd be willing to guess thats custom made.
    As are all great VX mods !
    Quote Originally Posted by ScottinMA
    '93 - '97 Rodeo. Our dash bezels are identical except the rodeo one is black instead of charcoal, and the fuzzy hole is replaced by a 3 switch panel blank. He's obviously modified the bezel to fill in the holes, but you could use it without fill in if you have the right combo of gauge and switch.
    99 white ironman
    hey, sorry, I picked up 50 hours of ot this past two weeks.. been kinda busy. I got the dash out of a 99 VX in a yeard outside of orlando... The VGA monitor is from ebay, and it's a no-name no-brand. brb
    So that bezel on the left side of the steering wheel came out of a VX? I thought they all came with the fuzzy hole feature. And, rodeo's came with a flat bezel as well? I must find this!
  1. Dash Mat
    By ipd in forum VX Modifications...
    Last Post: 10/20/2015, 09:13 PM
  2. Made my own Sub Box, and painted My Dash, with new dash pod.
    By CoastieCosta567 in forum VX Modifications...
    Last Post: 04/05/2007, 04:01 PM
  3. In-dash DVD
    By TechnoPope in forum VX Modifications...
    Last Post: 12/14/2005, 12:15 PM
  4. Jap dash in US vx?
    By MZ-N10 in forum VX Talk...
    Last Post: 10/05/2003, 11:43 AM
  5. Dash Kit
    By ChryLaser in forum VX Modifications...
    Last Post: 02/02/2003, 09:45 AM
