Results 1 to 6 of 6
Thread: Check engine light.
    Check engine light.
    My check engine light came on this evening.
    Engine runs fine, no strange noises.
    Anybody any ideas?
    And.............how do I reset this light, or turn it off?
    first thing to look for is tighten the gas cap.. and then wait a couple days (i think it takes 2-3 days to turn itself off when the problem is gone) if you want to get rid of it right away disconnect the battery for 30-60 minutes
    i would recommend finding out the code just in case.. when my CE light came on i bought a scangauge to read/clear the code.. $160 is definately worth it, clear/read codes twice and it pays for itself as most dealers charge 80+ to read codes, plus you can leave the scangauge hooked up all the time and get readouts, such as voltage, water temp, speed corrected for larger tires etc
    Aug 2005
    1999, silver, 0887
    Where do you get such a scan gauge? Thx.
    www.scangauge.com....
    ... buy through member Tone (www.tonemonday.com) and support a great VX.info member (and i think save 10 bucks)
    I just bought this one at the local shop for $125,-
    http://www.auteltech.com/gs300.htm
    Now see if it works..............
    Good gauge - just the SGII can be used daily to monitor a host of parameters that we don't have gauges for. I even use it my MB.
  1. first check engine light
    Last Post: 04/26/2010, 07:36 AM
  2. Check Engine Light
    Last Post: 11/01/2007, 05:57 PM
  3. Check Engine Light
    Last Post: 10/29/2007, 01:25 PM
  4. Check Engine Light...
    By dobie3 in forum VX Troubleshooting...
    Last Post: 12/11/2003, 02:45 PM
  5. Check engine light just came on...
    By Inaba in forum VX Troubleshooting...
    Last Post: 06/28/2003, 10:52 AM
