So I finally got the fairing in the mail after a coupl weeks wait from class cycle.com....The problem is I read that you really dont need the might mounts if you want to take out the weatherstrip out of the rack and slide the screws in. This is the way I wanted to go. I tried it and the fiaring would not sit probperly on the roof even after trying to tweak its stance/position. The foam pads did not touch the roof on the outside 2 bars. I am wondering if I was go purchase the might mounts I would not have this problem and would not have the wingnuts sitkcing in the air either.....And if so how would i cut off the back box on the mounts....
John
