Results 1 to 6 of 6
Thread: TOD problem
    TOD problem
    Please can anybody out there help. I am based in England where there are only a handful of Vehicross' in the country.
    My vehicle will not run in TOD mode. When I engage TOD the transmission throws all the power up front and it dorps into low dirve. In two wheel drive mode also it feels as though it is locking the rear dif if I try to accelerate whilst the steering wheel is turned even slightly.
    The car also has uneven wear on the front tyres and pulls strongly to the left.
    Please help.
    Thanks
    Mark
    May 2002
    2000, Proton Yellow, VX, 0584
    You're not using the little lever next to the gear selector are you?
    That is only to be used for 4x4 low.. The US Spec. don't have a TOD Switch ours runs all the time...
    Scott / moncha.com
    Thanks for the rapid response. Yes the little lever in the Japanese car has 2 wheel drive, TOD and low 4 wheel drive modes.
    The car can shift from 2 wheel drive to TOD on the move up to 50 mph.
    Do you know were I can get a manual on this Japanese car??
    Thanks
    mark
    Mar 2003
    1998 Blue standard 1198
    Hi Mark.
    I am a fellow U.K. Japanese spec VX owner I have found it easier to shift into the N position then apply changes to the drive i.e. going into low ratio Only when staionary!) I'm not sure if this helps your problem. I have found a mine of information from this site and initially contacted Scott who runs the Moncha site which gave me a lot of info on the VX
    The other U.K. owner I have contacted is Sam.
    Best regards
    David Wiltshire.
    Apr 2003
    1999 Astral Silver 1222
    This may be a longshot, but maybe your tires worn unevenly may cause the TOD to think tires are going at different speeds ie. one "spinning" even though its not. Ive noticed lately that instead of 2 light bars coming on at a dead stop acceleration run, now all 3 come on. on dry pavement. I think its from tire wear on mine.
    Thanks for all the replies, I have booked the car in for front to rear wheel tracking and alignment and will then replace all the tyres.
    Does anyone have the wheel alignment data for this car???
    Mark
  1. HID problem
    Last Post: 07/29/2010, 05:28 AM
  2. Driving problem fixed/TOD problem realized
    By mattlewis9333 in forum VX Troubleshooting...
    Last Post: 02/26/2010, 05:57 AM
  3. Possible TOD problem
    By BritVX in forum VX Troubleshooting...
    Last Post: 02/17/2010, 01:21 PM
  4. need a help again with another problem.
    By CoastieCosta567 in forum VX Troubleshooting...
    Last Post: 11/16/2007, 05:49 PM
  5. AC Problem
    By wwstone in forum VX Troubleshooting...
    Last Post: 07/22/2006, 06:37 AM
