Results 1 to 2 of 2
Thread: I've searched and searched...
    '01 Ebony #0939
    I seem to remember a thread awhile back where someones' VX lunged forward when the engine rpm jumped up as they put their foot on the gas pedal and moved the gear selector from Park to Drive.
    As my thread title says, I've searched using all the search terms I can think of that might relate to the problem, but haven't had any luck finding a thread regarding a similar experience and fix. (Something to do with a brake fluid reservoir sensor?)
    Sound familiar to anyone?
    Erratic idle either up or down can be caused by vacuum leaks (intake gasket), clogged idle control valve on the throttlebody and/or the pressure switch on the power steering pump.
  1. How are you guys wiring your roof mounted lights. (I searched)
    By taylorRichie in forum VX Modifications...
    Last Post: 06/24/2013, 03:05 PM
  2. Need Bilstein 5100 Part #s (yes, I've searched)
    By E-ZooZoo One in forum VX Modifications...
    Last Post: 11/14/2009, 10:52 AM
  3. Turn Signal Problems....YES..I searched!!
    By JoFotoz in forum VX Troubleshooting...
    Last Post: 03/08/2009, 07:25 PM
