Just came back from a road trip from the holidays and noticed my VX getting louder like a darn big ol' deisel truck or something. Anyone else have this trouble? Any ideas to what is causing it?
Thanks!
Stacey
Thanks!
Stacey
Sounds like the EGR value needs to be tightened... check the EGR nut attaching the EGR tube to the bottom of the valve. Here is my post back when I was having weird sounds, turned out to be the EGR...
http://www.vehicross.info/forums/sho...&highlight=EGR
While we're on the subject of unwanted noises, I wanted throw something in. I developed a pretty annoying rear door rattle and couldn't find anything wrong. Like has been said before, sound travels through vehicles in weird ways. Because of the location and all, I really did not think it could possibly be it, but for the heck of it I finally removed the metal license plate frame. Not a peep since.
Yep, just had to tighten the nut on the bottom of my EGR valve for the same reason. From reading about the symptom and cause on this site awhile back, I expected that the nut must be somewhat loose when I started to hear the dieseling sound coming from the engine bay, but I sure didn't expect it to be backed out of the EGR valve ALL THE WAY, and simply wobbling around on the tube about two inches below the valve!
Anyway, nut has been tightened, and no more noise.
Incidentally, the change in operating conditions with the nut tightened was enough to produce a check-engine code/light on the dash. I reset it by disconnecting the (-) battery cable for awhile, and so far it hasn't come back on.
Can I tighten this nut myself? What tool do I need to use? Or do I need to take it to the mechanic?
Thanks for the input.
Misterdallas
I found out (to my dismay,not on the VX though) that this dieseling sound can also be caused by a loose or flopping spark plug. It scared the hell out of me when it happened. She went from "Hummm to Bam Bam Bam" real quick.
I make it a point to check ERG and plugs once per month...once was enough for me![]()
John
You can tighten the nut yourself. It can be a pain in the arse to thread back into the bottom of the EGR vlave mount, but it can be done. Before I had the SC kit installed I think I had re-tightened the nut 3-4 times... after the kit was installed it didn't slip once.Originally Posted by misterdallas
Can I use the slip wrench? What would be the best tool?
Thanks so much for the input.
Misterdallas
A 22mm stubby wrench is the way to go,Sears has them.I carry one in the glovebox at all times.
