Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: How do I fix???
  1. #16
    You can drive the VX with no problem,is doesn't harm the performance,but if you got to inspected it wouldn't pass emission test,that's all
    And there lies my problem. Must get it fixed to pass emissions..
    Scott
  2. #17
    Just purchased the parts from Marvin, a canister and valve for a little over $200. I decided to crawl under it yesterday and do the replacement and the check engine light goes off! This truck is playing with me. It did get warmer and I wonder whether temp may play a part in this saga. So, my plan is to drive around with the parts in the back seat cause I know the moment I put them in the garage the check engine light will come back on.
  3. #18
    Jan 2008
    1999 Astral Silver 0481
    Hahahaha that's so funny though.
    Actually,after replacing the canister my engine lit was still popping on,however,after my mech worked on the engine the lit didn't came on any more.
    Now,there's something you got to know,you must replace both vent solenoids the one located at the rear & the other located right under where the intake pipe conects to the intake manifold.
    I'll also go almost tank empty to eliminate all vapors in the fuel tank before the ECU is reset.
    Dakar was just the begining.
  4. #19
    Sounds good..thanks Gussie
