I went into the performance shop the other day to get a feel for the quality of work these guys do on exhaust systems (the speed shops and hot rod buffs all recommend this place). I found that they seem to know what they're doing and do some good work, however, he made a few interesting comments:
1.
He recommended that instead of the typical look where the two tips point straight back, I should have them angled a bit down and also point about 45 degress to the side. His reasoning was that the air stream around the VX will keep some exhaust fumes rolling around the rear tailgate and that there is the possibility that the fumes could be sucked into the car through any gap in the tailgate seal.
Has anyone experienced this or heard of this?? Most new SUVs have rear pointing exhausts (although most vans don't..).
2.
Also, does anyone really feel that smooth bent pipes will noticeably lower performance compared to mandrel bent pipes? (There's no mandrel bender in the City here - special order required)
Thanks for any thoughts...
Ken
