Results 1 to 6 of 6
Thread: Got a problem
    2000 IronMan #11
    Exclamation Got a problem
    Ever since i bought my VX just on the 2nd of this month, it has always taken its time to start. I will turn the key over with no results untill about 10seconds has passed, although i find that when i press on the gas the engine starts quicker. After starting the rpm's bounce and if i dont press on the gas a little they would bonce and hault at 0 and the engine would die. Now as of the last two/three tanks of gas my mpg has dropped drastically to about 13/14 average. When i first drove this thing home 7 hours i was getting 18/19 easy while driving near 85mph constantly.
    My question is. Would a fuel pressure regulator cure this? I think im running rich on gas causing the low mpg now?
    If this isnt not the correct cure please fill me in on what to do. I dont want this mpg when the gas prices go back up, and i would like to enjoy these prices at the time being.
    Please advise me on the correct thing(s) to replace/check to get er' running normal.
    John
    i would definately start with the fuel pressure regulator you can order them online for about $50 and should be fairly easy to install, its a low cost place to start, and chances are itll cure your problem
    Check the intake gasket for leaks first.
    2000 IronMan #11
    And how would you do that? Explain, I am a novice at this stuff. Thanks.
    Whole site search is your FRIEND.
    Try using "intake gasket" & you'll be amazed at how much you can learn.
    I found the answer to your Q in less than 5 min.
    Sep 2005
    1999 Astral Silver VX #0351
    Yes, check for leaks at the intake gasket or EGR. The dancing idle is many a times a sign of an air leak.
  1. HID problem
    Last Post: 07/29/2010, 06:28 AM
  2. Driving problem fixed/TOD problem realized
    By mattlewis9333 in forum VX Troubleshooting...
    Last Post: 02/26/2010, 06:57 AM
  3. Possible TOD problem
    By BritVX in forum VX Troubleshooting...
    Last Post: 02/17/2010, 02:21 PM
  4. need a help again with another problem.
    By CoastieCosta567 in forum VX Troubleshooting...
    Last Post: 11/16/2007, 06:49 PM
  5. AC Problem
    By wwstone in forum VX Troubleshooting...
    Last Post: 07/22/2006, 07:37 AM
