My VX has had problems sence the first day the I got it. The main issue right now is that its starting to shift a little rough. Also I went to get in it to go back to work today and it didn't want to start. It would turn over and run up the rpm's a little like it should but then it would drop all the way back down to 0 and shut off. I got it to run after giving it quite a bit of gas. Also from a cold start, in the morning after its been sitting all night or sitting all day at work, I start it up and it stays at 2k or so and then when I put it in gear it drops back down. Does anyone know whats going on? Its starting to get to the point that I am truly thinking about selling it.
