Results 1 to 10 of 10
Thread: Bolt size
    Bolt size
    Hello,
    Can someone tell me the size in mm the oil pan drain plug bolt is?
    I do not have a wrench big enough and I want to go buy a nice one for changing the oil, but I cannot find the size in the manual anywhere.
    Thanks - Bart
    Arrow
    Reading previous posts now, looks like 22mm??? Is this right?
    Thanks - Bart
    22mm
    Nov 2002
    No wrench required.
    Oh, if you have a Fumoto.
    Thanks!
    I got a 22mm wrachet bit and a breaker bar and it came loose in a matter of milliseconds with that.
    Tell me more about this Fumato valve?
    Nov 2002
    The Fumoto valve is basically a low-profile quarter-turn ball valve with a locking detent. You replace your drain plug with it and whenever you need to drain oil you just reach under and turn the tab. That simple.
    Many folk have commented that since it sticks out about an inch that it could get damaged, but the reality is that if you knock one off then there was a lot more knocked off along with it (like a good chunk of your suspension).
    I use them on all my street vehicles, my Caterpillar dozers and any other equipment they have fitment for. On stuff like my 25-ton crane they make a version with a nipple for fitting a hose, so you can drain to a remote location. The crane's diesel engine is mounted in the rear of the house (crane cab) and it's not the easiest thing to crawl around in, especially with all the winches, clutches, linkages and cables in there. Same deal with the dozers since they have thick steel armor protecting the engine below, so I can just snake a hose out the side and through the tracks to a bucket. Wish I had done the same thing for the Detroit Diesel in my semi-tractor too, as it's a long way from the drain the to ground!
    Here's a link to their site: www.fumotovalve.com
    Any questions about real-world use and function, just ask!
    Apr 2003
    Hmmm.
    Which Fumoto fits the VX?
    F106? F107? F105? other?
    Thanks!
    drip, drip, drip goes the expensive motor oil
    I purposefully left an old cardboard box under the front end of my VX, I just checked it and my plug was dripping, so I tightend the bolt a little more. Hopefully it will stop, didn't want to overtighten....
    That Fumato valve sounds pretty nice right about now.
    Nov 2002
    F106.
    Apr 2003
    Quote Originally Posted by Joe_Black
    F106.
    cool thanks!
  1. Bolt size for rear seat.
    By housertl in forum VX Troubleshooting...
    Last Post: 12/10/2011, 06:09 PM
  2. License Plate Bolt Size
    By Child's Play in forum VX Talk...
    Last Post: 06/25/2011, 08:35 PM
  3. 10 bolt lockers available again
    Last Post: 08/09/2009, 01:32 PM
  4. Rim size/Tire size
    By Dumke in forum VX Talk...
    Last Post: 01/31/2007, 04:00 PM
  5. WMS - WMS VX 12 bolt?
    Last Post: 01/31/2006, 06:12 PM
