I cannot recommend one of the three Trooper skid plates. The one called "Exhaust pipe protector"-
part #8-97018-375-3, list price $115.10, your cost $97.84.
This is the plate on the passenger side that shares the center and driver's side bolts on the cross member and attaches at two points on the frame. This plate protects the front driveshaft and the two transmission pans. The shape is unnecessarily low. A space of 5" results between the transmission pan and the plate. A large 3.5x8" access holes exist at the bottom which will snag anything you are scraping across. It becomes the lowest point of the underside. I waited 6 weeks for this and would suggest you make your own for better protection and clearance. I may modify this one, but it will not be pretty.
Roy
