So VX completely looses ALL power when turned to the "on" position. Any ideas?
Headlights (Tone's HID's) will not come on at all, even with key out of ignition. I took the fuses out of the HID's, VX still loses all power when key is turned to the on position.
Alarm will not lock or unlock doors. Inside power door lock will not work at all, sounds like it tries and cannot turn on. Checked all fuses inside VX all are fine. Tried to turn key to on position while ACC fuse and headlight fuse and other fuses were out individually nothing worked. DVD player was messing up getting power when it should not in the ACC line and turning the cd inside around when power is off.
I took the whole interior apart and took out DVD player and disconnected all ACC items. Nothing seems to help entire VX loses power when key is turned to on position. But why will the HID's not come on no matter what? I don't get this, the VX is right now in the Kroger's Grocery store in not the best neighborhood in Houston, TX. HELP HELP HELP. Isuzu repair dept is not open on sundays I do not think. The only weird thing that happened tonight was my buddie tried to open the door while I was unlocking it and then it would not unlock I had to relock it and then unlock it and it made a loud sound, but I have had that happen multiple times in different cars...... I am so frustrated! First night my VX is not safe in my care. HELP!!!!!
Thanks In Christ,
Ryan H
USA Decathlon Team
