My VX began noisy and I found the expansion unit (2-inch long bellows shaped pipe) on left exhaust pipe system.![]()
The mesh tubing was almost disappeared and the expansion unit is broken.
My local garage introduced anther garage to cut that part and weld another piece of pipe, and I talked to the one but he said it did not work on a Trooper.
It looks to me that the area is volunerable and could be problem to all VXs. Didn't you guys have similar problem? If so, did you find a good solution?
Thanks guys in advance.
