Results 1 to 4 of 4
Thread: Stumped
    Aug 2003
    2000 Victory White Ironman 0757
    Stumped
    3 belts chewed up, the bearings keep separating from the shaft on the fan pulley. Brand new pulley, replaced twice. ANY ideas?
    Bearings on the fan pulley? You mean the fan clutch? Sounds like an out of balance fan - I have an extra (I think) if you need one. The tensioner or idler pulley bearings could be failing which could cause the belts to be eaten. Item causing problem should either be visible when the engine is running or by pushing on all of the pulleys with the belt off.
    Aug 2003
    The fan does wobble; the part w/ 4 bolts that connect the fan to the mounting bracket keeps sliding forward, if that makes sense.
    How much do you want for your fan?
    Aug 2003
  1. Stumped on Color Codes
    By Francesco Rizzo in forum VX Troubleshooting...
    Last Post: 06/12/2008, 07:07 PM
