Another useful tip I learned growing up:
When you encounter a filter that's on too tight, rather than going immediately for the wrench, do this:
- wrap it with a shop towel to help you grip
- put slow, steady pressure on it - it'll move very slowly
What's happening when you over-crank it on removal is you cause the rubber seal to bunch up and just make it harder. Slow, steady pressure gives the rubber time to reacclimate and slip around. I've had to hold on for minutes before, but have gotten filters off that the 'ole screwdriver trick wouldn't touch.
