Results 1 to 15 of 20
Thread: DIY Oil Change process
nfpgasmask DIY Oil Change process 08/21/2006, 12:14 PM
VCrossfan Sent to me by a friend...Girl... 08/21/2006, 01:02 PM
nfpgasmask So, VCrossfan, you gonna... 08/21/2006, 06:19 PM
Joe_Black Pretty much, but omit step 5... 08/21/2006, 01:03 PM
etlsport when i changed my oil, i... 08/21/2006, 01:08 PM
Ldub The "Other" first step should... 08/21/2006, 03:09 PM
nfpgasmask OK guys, thanks for the tips.... 08/21/2006, 03:22 PM
Joe_Black I hate to say so, just... 08/21/2006, 06:10 PM
    Question DIY Oil Change process
    OK folks, for those DIY experts, can you tell me if this is about right for an oil change process?
    1) Open drain plug and drain all the oil
    2) Remove oil filter
    3) Close drain plug and install new oil filter
    4) Fill engine with fresh oil
    5) Change air filter
    Does that sound about right? I know this is a simple process, but I've not done it myself yet. I don't wanna miss any steps. Any tips/tricks are also welcome. I have all the tools/supplies ready, and all I need now is a new air filter and oil filter (any suggestions on good brands to look for?). Also, about how many quarts will fill me up after a change?
    Thanks! Bart
    Sep 2004
    1999, Astral Silver, VX, 0938
    Sent to me by a friend...Girl of course
    Oil Change instructions for women:
    1) Pull up to Jiffy Lube when the mileage reaches 3000 miles since
    the last oil change.
    2) Drink a cup of coffee.
    3) 15 minutes later, write a check and leave with a properly
    maintained vehicle.
    Money spent:
    Oil Change $20.00
    Coffee $1.00
    Total $21.00
    Oil Change instructions for men:
    1) Wait until Saturday, drive to Auto Zone parts store and buy a case of oil, filter, kitty litter, hand cleaner and a scented tree, write a check for $50.00.
    2) Stop by 7 - 11 and buy a case of beer, write a check for $20, drive home.
    3) Open a beer and drink it.
    4) Jack car up. Spend 30 minutes looking for jack stands.
    5) Find jack stands under kid's pedal car.
    6) In frustration, open another beer and drink it.
    7) Place drain pan under engine.
    8) Look for 9/16 box end wrench.
    9) Give up and use crescent wrench.
    10) Unscrew drain plug.
    11) Drop drain plug in pan of hot oil: splash hot oil on you in process. Cuss.
    12) Crawl out from under car to wipe hot oil off of face and arms. Throw kitty litter on spilled oil.
    13) Have another beer while watching oil drain.
    14) Spend 30 minutes looking for oil filter wrench.
    15) Give up; crawl under car and hammer a screwdriver through oil filter and twist off.
    16) Crawl out from under car with dripping oil filter splashing oil everywhere from holes. Cleverly hide old oil filter among trash in trash can to avoid environmental penalties. Drink a beer.
    17) Buddy shows up; finish case of beer with him. Decide to finish oil change tomorrow so you can go see his new garage door opener.
    18) Sunday: Skip church because "I gotta finish the oil change." Drag pan full of old oil out from underneath car. Cleverly dump oil in hole in back yard instead of taking it back toservice station to recycle.
    19) Throw kitty litter on oil spilled during step 18.
    20) Beer? No, drank it all yesterday.
    21) Walk to 7-11; buy beer.
    22) Install new oil filter making sure to apply a thin coat of oil to gasket surface, be sure filter is full of oil.
    23) Dump first quart of fresh oil into engine.
    24) Remember drain plug from step 11.
    25) Hurry to find drain plug in drain pan.
    26) Remember that the used oil is buried in a hole in the back yard, along with drain plug.
    27) Drink beer.
    28) Shovel out hole and sift oily mud for drain plug. Re-shovel oily dirt into hole. Steal sand from kids sandbox to cleverly cover oily patch of ground and avoid environmental penalties. Wash drain plug in lawnmower gas.
    29) Discover that first quart of fresh oil is now on the floor. Throw kitty litter on oil spill.
    30) Drink beer.
    31) Crawl under car getting kitty litter into eyes. Wipe eyes with oily rag used to clean drain plug. Slip with stupid crescent wrench tightening drain plug and bang knuckles on frame.
    32) Bang head on floorboards in reaction to step 31.
    33) Begin cussing fit.
    34) Throw stupid crescent wrench.
    35) Cuss for additional 10 minutes because wrench hit bowling trophy.
    36) Beer.
    37) Clean up hands and forehead and bandage as required to stop blood flow.
    38) Beer.
    39) Beer.
    40) Dump in five fresh quarts of oil.
    41) Beer.
    42) Lower car from jack stands.
    43) Accidentally crush remaining case of new motor oil.
    44) Move car back to apply more kitty litter to fresh oil spilled during steps 23 - 43.
    45) Beer.
    46) Test drive car.
    47) Get pulled over: arrested for driving under the influence.
    48) Car gets impounded.
    49) Call loving wife, make bail
    50) 12 hours later, get car from impound yard.
    Money spent:
    Parts $50.00
    DUI $2500.00
    Impound fee $75.00
    Bail $1500.00
    Beer $40.00
    Total - - $4,165.00
    But you know the job was done right!
    So, VCrossfan, you gonna drive up for a Chicago meet? Or are you too far south?
    Nov 2002
    Arrow
    Pretty much, but omit step 5 for the air filter. You should change your air filter about every 10K miles unless you're using a K&N, in which case you would wash and re-oil. They're guaranteed for a million miles.
    Also, a good rule is to replace your PCV valve every other oil change. They're cheap at less than $4 each, and when they fail is what causes excessive oil consumption in most engines. Since I use the Mobil-1 M104 oil filter I'll order them 5 at a time from www.autozone.com and always get a handful of PCV valves too.
    when i changed my oil, i opened the oil cap in the engine while i was draining, maybe it was my imagination, but i think it helped the oil drain faster, i also jacked up the rear passenger wheel off the ground w/ the stock bottle jack to make sure the plug was by far the lowest point in the oil pan to be sure i got all the oil out. i had some trouble gettin my oil filter off, used a mousepad to help (the bottoms of the old style mousepads are really sticky, so it helps grip the filter, plus provides some protection from the heat if your engine has been running recently
    id also change out the PVC valve while youre at it, its cheap and easy, even if it doesnt need to be done, better safe than sorry
    make sure youve got a good wrench to get the oil plug off, mine was a huge pain, and my adjustable wrench wouldnt cut it, so i had to go buy a 22mm wrench and that took it off with no problem good luck!
    if you run into any trouble you can always shoot me an IM on AIM.. im usually pretty easily reached there (etlsport)
    The "Other" first step should be to warm up the oil (like driving to autozone) so any particulate matter and/or gunk is in suspension when you drain the oil.
    I doubt taking off the fill cap makes it drain much faster, I've never tried it, but it still drains almost too fast & has a tendency to splash off the side of the drain pan.
    The breather tube located next to the filler allows more than enough air in through the intake.
    My two cents.
    OK guys, thanks for the tips. I'm gonna do the PCV for sure. I did it last oil change and I will order some more when I order the oil filters.
    So, JoeBlack, the Mobile 1 oil filters are good then?
    Thanks everyone,
    Nov 2002
    Arrow
    Quote Originally Posted by nfpgasmask
    I hate to say so, just because they're Mobil-1 which makes me look like a major nut , but there's no paper or cotton gin waste in there like all the other filters. Pretty much built like a Wix XL commercial truck filter: all synthetic fibers. Excellent filtration and I've been using them in several vehicles since they came out with fantastic results.
    Cool, I will try to find these around here or just order them from AutoZone.
    Thanks - Bart
    Quote Originally Posted by Joe_Black
  1. Cleaning/Restoring process for OEM roof racks
    Last Post: 12/08/2012, 04:31 PM
  2. oil change
    By etlsport in forum General Tips...
    Last Post: 06/30/2006, 12:19 PM
  3. thread picture process
    By jacobus in forum VX Talk...
    Last Post: 01/21/2006, 06:04 PM
  4. Know anything about chroming process?
    By WyrreJ in forum VX Modifications...
    Last Post: 09/21/2003, 11:24 AM
  5. oil change
    By RobVX in forum VX Troubleshooting...
    Last Post: 03/12/2003, 01:55 PM
