Results 1 to 9 of 9
Thread: Timing Belt Replaced - Crank Pulley Question
    Feb 2004
    '01 Ebony #0830
    Hi,
    I just replaced the timing belt... all good... but now trying to figure out how in the world to hold the crank pulley in place while I tighten the bolt!
    Any suggestions???
    Also, does anyone know off-hand what the torque spec is for the crank pulley bolt?
    Thanks!!!
    ---JIM---
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    With the fan belt back on you should be able to tighten it no problem. I think the spec is 100 ftlbs but that is just off the top of my head. I posted those specs a few years back under a SC post - I've got it at home and can verify tonite.
    Feb 2004
    '01 Ebony #0830
    Thanks!!!
    Thank you Tone!!! MUCH appreciated!
    I was at a standstill...
    ---JIM---
    TORQUE SPECS
    EGR Nut 21 lb ft
    Crankshaft Pulley 123 lb ft
    Fan pulley and bracket 16 lb ft
    fan and clutch assembly 88.5 lb ft
    idle pulley bracket 38.4 lb ft
    throttle body 18 lb ft
    Intake manifold 18 lb ft
    be sure to clean threads
    '99 Ebony VX #0038
    There was a TSB put out that changed the torque specs on the intake manifold gasket to 13 lb/ft (NOT 18 lb/ft). Presumably torquing to 18 lb/ft will eventually cause the gasket to leak again.
    Feb 2004
    '01 Ebony #0830
    Tone,
    Thanks for the specs!!!
    One problem... I got the belt back on, but even with a new tensioner it's not strong enough to hold the crank pulley for me to tighten it to 123 lbs... any ideas???
    Anyone? Anyone? Beuler? Beuler?
    Thanks!
    ---JIM---
  1. Another timing belt thread question
    By ahdoman in forum VX Troubleshooting...
    Last Post: 08/30/2014, 04:20 PM
  2. Quick question on Timing belt?
    By CoastieCosta567 in forum VX Troubleshooting...
    Last Post: 08/23/2014, 10:45 PM
  3. Timing Belt Change Question
    By TexasProton in forum VX Troubleshooting...
    Last Post: 02/08/2014, 06:08 PM
  4. Question on Timing Belt Change Issue - Bart?
    Last Post: 04/22/2012, 06:42 PM
  5. crank pulley size question
    By spitfire5454 in forum VX Talk...
    Last Post: 02/03/2006, 03:55 PM
