Results 1 to 12 of 12
Thread: Brake problems> HELP
    '99 Ebony Black VX, 0339
    If they need to be turned it is usually better to go ahead and replace the rotors as it will only be a matter of time before they warp from being thinner. And new rotors are cheap if you do it yourself or an arm and a leg if you let a brake shop do them.
    2000 IronMan #11
    Arrow
    Very new to the mechanical aspect of cars....Grew up in a family that belives car repair is left to the mechanics and not worth the money saved for the time it would take yourself to do the work.......As bad as this may or may not sound. How do you do you change your rotors/pads? And how difficult is it and what tools would be needed. I guess everybody has got to start somewhere with learning this stuff..
    Jun 2005
    2001 Black VX
    Tone has more mechanical experience in his little toe than all of mine put together, and even I feel confident doing a brake job.
    The way I learned was to have a friend help me out who knows what they are doing AND who has all the RIGHT TOOLS. Once you have someone show you, you'll realize that its really easy.
    Or, you can take one of those community college courses to learn- Ive never taken one, but Im sure they cover a lot of the basics.
    Just my 2 cents.
    '99 Ebony VX #0038
    Creeg is right. Start small, and bring a friend. That's how I learned. I started doing oil changes and now I'm thinking of doing an engine swap one day. And I'm definitely not the typical "grease monkey" type.
    As for your "not worth the money" logic, let me explain how I decided to do all my own work. First, we all know that we take much better care of our own stuff than anyone else will, so it makes sense to know your vehicle and how to maintain it. That is the most important point in my opinion. It will save you a TON of money byi catching little problems early before they become big problems. Second, think about this. Let's say your mechanic charges $80 an hour. How much is your time worth and how long will it take you to do it? A good measure of how much your time is worth is how much someone else is willing to pay you for your time. A lawyer who makes $100 an hour shouldn't do his own work, but his secretary, who makes $20 an hour, probably should. Does that make sense? Even if it takes you twice as long as the mechanic, until your time becomes worth more than $40/hour, it makes more sense for you to do it yourself.
    2000 IronMan #11
    Arrow
    kpaske - ha funny you made refernce to an attorney doing mechanicail work...Im in law school and my dad has been practicing for about 30 years now, so that explains exactally why i grew up in a family that belives car repair is for the mechanic....
    BUT........
    Is there any type of walk through or steps on here i could take that would be helpfull for repair. I really want to fix them myself.
    Brake pads are a pretty basic DIY job IF you have any mechanical aptitiude at all - I taught my brother to do his Infinity's in 10 minutes (although the backs he got confused on later....) Basic hand tools, patience and logic are all that is required. The VX workshop manual has a bit of a step by step or check a Chilton's book for some idea of what you are in for. Remove the 2 bolts that hold the caliper on and slide it off the rotor. If the rotor is not torn up, then stick a screwdriver in between the pads and spread them as far as they will go. Put the new pads on, slide the pads and caliper back on and lube the pin ends (VERY IMPORTANT SINCE THE CALIPERS FLOAT ON THESE PINS) with hi temp grease and retighten them. If ya gotta change the rotors, you'll probably want someone right there beside you or definitely refer to the manual.
    Jun 2005
    2001 Black VX
    Yup, Chiltons is the way to go.
    Also do a search on how to change out brakes on the web. If you go into it armed with knowledge about what you are doing, should go smoothly.
    good luck.
    http://auto.howstuffworks.com/disc-brake.htm
    i find that working on parts of my cars is made much easier by knowing exactly how all the pieces work together
  1. TOD Problems
    By Benny in forum VX Troubleshooting...
    Last Post: 02/05/2014, 12:15 PM
    Last Post: 12/14/2011, 01:15 PM
  3. More Problems
    By I_Wanna_Retire in forum VX Talk...
    Last Post: 02/07/2006, 02:54 PM
  4. Problems
    Last Post: 11/28/2005, 02:53 PM
  5. A/C problems
    Last Post: 07/20/2004, 12:32 PM
