I'm in need of a wiring harness (plug) for a digital equalizer Pioneer model DEQ7600. Any ideas on where could I get one?
Thanks,
Thanks,
Daniel
Best Buy or pretty much anywhere else that sells/installs car audio.
Are you trying to hook that DEQ up to the stock stereo? You would probably need to splice into the line-level outputs and convert to RCA inputs into the DEQ, but this is not the preferred way to add an EQ and your sound quality will suffer. What you really need is a replacement head unit with RCA outputs.
I'm replacing the headunit with a Sony CDX-RA700. It does have RCA connections.
Preamp/RCA Outputs 3 Pair - Front, Rear, Sub
So... the only wires you should need for the DEQ are RCA's in and out (unless you're going line-level straight to the speakers, but in that case it's just standard speaker wire). What you might need a harness for is the head unit, and like Triathelete said, you should be able to get that at just about any car stereo shop, or you can try online at places like crutchfield.com or sounddomain.com. Does that answer your question, or am I misunderstanding what you are trying to do?
Please see pics. Top is the headunit, below is the EQ. I have the harness for the headunit, but I don't have whatever connects where the 4 pins are in the EQ (lower right). Do I need a harness for the EQ?
I'm not familiar with the RCA connections. I guess the two RCA outputs from the headunit go to the EQ RCA connections. But how do I power up the EQ? Seems to me that I need the harness. Please advise and sorry for the naive questions. Last time I installed a unit was "wire-to-wire".
Thanks
