Results 1 to 8 of 8
Thread: Limited Slip
    Apr 2003
    ex IronMan
    Limited Slip
    Hi,
    I have my VX on the lift and when we run it all 4 wheels rotate. Is that correct ? When we stop the engine wheels on one axel seem to be "locked" - they rotate together. I can not understand how this can be right ??? One wheel should rotate independantly from another one. What might be the problem here ?
    thanks
    Andrey
    Nov 2002
    Arrow
    That's the differential at work doing what it's supposed to do.
    What usually freaks most people out is when they see the other wheel moving in the opposite direction of the wheel they're turning by hand.
    Dec 2004
    I don't think I'll ever comprehend why that happens...
    2000, Black VX #0754
    Correct the Vehicross has a limited slip differential.
    With a limited slip differential if you jack up the axle and spin the tire the other tire will spin in the same direction. With an open differential the other tire will spin in the opposite direction.
    Nov 2002
    Quote Originally Posted by VehiGAZ
    Yup, differentials are different!
    Apr 2003
    ex IronMan
    wow.. so it is working right ! I can not understand how we are not wearing tires when we make turns ??? does it allow for some slipping ?
    Nov 2002
    Arrow
    That's where the "limited" in limited slip comes into play. Some VX's will chatter a bit from the rear diff when turning tight at full lock, and that's the LSD trying cope with the short wheelbase.
    Apr 2003
    ex IronMan
    Harmonics
    I see, thanks !
    Now comes the harmonics vibration at 50 mph. Anybody had issues with harmonics ?
  1. Replies: 6
    Last Post: 10/08/2012, 08:50 AM
  2. Door Handle Non-Slip Tape.. Free to the first 20!! maybe more
    By VCrossfan in forum VX Modifications...
    Last Post: 08/27/2009, 06:36 AM
  3. Registry for the 175 Limited, Blue VXs.
    By kodiak in forum VX Talk...
    Last Post: 04/23/2008, 01:54 AM
  4. FRONT Limited Slip???
    By E-ZooZoo One in forum VX Talk...
    Last Post: 01/25/2007, 06:56 AM
  5. Front Limited Slip
    By Charon_Sin in forum VX Modifications...
    Last Post: 07/28/2004, 02:41 PM
