Ok, I just can't get the air horns to work. So I'm putting the old ones back on.
I just can't find where the wires are for the drivers side are can some one tell me or show me with a pic? thanks again!![]()
Knowledge is power!
There are two horns on the VX - one hi and one lo note. They are relatively close to one another but the passenger side one is lower behind the cladding. Take the grill off (4 10mm bolts and 3 phillips head screws) and you should be able to see the 2-wire connectors. Often airhorns require a bigger fuse and/or relay than what comes on the VX. If you are having trouble getting the airhorns to work, you may want to start there...
thanks man!
all working now!
