Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: Oil Change Check List
  1. #16
    RE: Purolator 1061
    Yes, I use them & I like em'...& here's why, they use the weight of the ball bearing inside to control flow rather than being spring loaded.
    This gives them a rattle when you shake them, so It's easier to tell if they're gummed up or not.
    Thaz jus my two cents on PCV valves...worth exactly what ya paid.
  2. #17
    Exclamation I can't believe I actually paid to have this done before...
    I just finished changing my own oil! Wow, that was WAY easy. I honestly can't believe they charge $75+ to do a Mobile-1 change at Jiffy Lube.
    I must say however, the worst part is carefully pouring my spent oil back into the containers. I made a little bit of a mess but not too bad. Might need a little Oil Dry here and there
    The old oil filter came off with no problem, just unscrewed it and didn't even have to give it any pressure. The drain plug on the other hand was a little whore to get off. I ended up going BACK to Pep Boys for the 5th time in the last 36 hours to buy myself a 22mm wratchet bit and a breaker bar. Then it was like butta.
    Anyway, VX running smooth, no CE light, no rough idle. TIME FOR CELEBRATION!
    Thanks everyone for the help.
    PS - Yes, I also put in a new PCV Valve
  1. Should we be on this list?
    Last Post: 12/02/2010, 07:06 PM
  2. VX check list
    By Anita in forum VX Talk...
    Last Post: 03/08/2010, 06:13 PM
  3. My Mod list... what else?
    By killinformula in forum VX Modifications...
    Last Post: 12/20/2008, 01:04 PM
  4. Next on the List...
    By Thejerseyfish in forum VX Troubleshooting...
    Last Post: 02/16/2007, 11:13 AM
  5. Are You On The Nov 9 List?
    By BumbleV-X in forum Meets...
    Last Post: 08/11/2003, 12:05 PM
