Results 1 to 4 of 4
Thread: Intake gasket
    2000,black,029
    Intake gasket
    Well my wife to be called me the other day from work and said her trooper started to stall at idle and the check engine light came on. I got a scanner and checked the codes.
    Bank 1 and 2 lean. I monitored the o2 sensors and bank 1 was switching normally but bank 2 was stuck at 89mv. Bank 2 sensor 2 was also low. Fuel trims on both banks was +40%. I sprayed some brake cleaner near the intake gasket and as soon as I did the 02 sensors would go full rich. You could actually hear it suck in the fluid. Just thought I would throw this out for everyone. Perhaps you could use some of the info to give to your dealer if you have a stalling concern.
    Andy
    Andy from Isuzu America
    May 2002
    2000, Proton Yellow, VX, 0584
    Thanks Andy!! You are a true wealth of info!!
    Scott / moncha.com
    Why are the intake gaskets failing? that never happens to a small - block chevy?
    2000,black,029
    The upper intake is plastic and the lower is aluminum. They expand at different rates and this causes wear on the gasket as this occurs.
  1. intake gasket
    By bulldog in forum VX Troubleshooting...
    Last Post: 07/12/2006, 02:29 AM
  2. Intake gasket. Do it yourself
    By andy454 in forum VX Talk...
    Last Post: 02/21/2004, 08:20 PM
  3. intake gasket leak !!
    By psychos2 in forum VX Troubleshooting...
    Last Post: 01/02/2004, 09:49 AM
  4. Part # for intake gasket
    By deton8r in forum VX Modifications...
    Last Post: 05/10/2003, 03:57 PM
  5. Bad intake gasket
    By JRB in forum VX Talk...
    Last Post: 03/21/2003, 07:10 AM
