Need some help identifying a plug. Finally got around to changing the flasher unit for the LED's, WHAT A B!@#$. I have the seat removed, half of the dash, you name it. I think it would of been easiler to remove the windshield and cut a hole in the top of the dash. Anyway, I came across this plug that was not plugged in. I assume that it is part of the factory alarm system and the dealer's service dept. disconnected it when I had a aftermarket alarm and remote start installed. Do any of you out there in VX land recognize it?
