Results 1 to 6 of 6
Thread: Help with wiring custom front signals
    tap into the cigarette lighter in the center console, at least in my vx, no key= no phone charging
    as for the parking light, which are you talking about? the ones below the headlights, i just reached down behind the front bumper from the engine bay into the area behind the light, youll feel the socket, it works the same as the socket for the horn light at the top of the headlight, you just twist it a quarter turn or so and it will slide right out.... id replace them with 18w lights from malibu that you can find at home depot.. they are a jillion times brighter than the stock ones
    2001, Dragon Green, 1342
    It might be the flasher unit. I remember wiring a trailer light plug, and do to the extra apmhere, it doubled the flash speed. Just a thought.
    Sep 2003
    1999, Black, VX1, 0813
    Oh yeah...
    I tried them with the third lead hooked directly to the battery's 12v and they worked properly without speeding up the blink. I just don't want to hook it directly to the battery since I'm sure it'll slow-drain it. Since the indicators are LED's they'll certainly draw less, but I know giving 12v to the third lead solves the problem, it's just a matter of where to get the juice from.
    Also, I want to avoid having to route wires all the way back to the cabin of the vehicle if possible, since I'd have to find a spot to poke through the firewall, it'll look ugly and I know there's gotta be a good place to tap somewhere in the front of the car.
    Thanks
    theres a grommet through the firewall towards the top of the firewall on the drivers side, to the left of the master cylinder if i remember right, should come out behind the speedometer... thats all i can think of, you could look through the fuse box in the engine and see what you find, maybe power for the windshield wipers if you can find where it goes through before the switch
    99' Astral Silver
    I ran my fog light wires through the fire wall on the drivers side, if I'm not mistaken they came in to the cabin well below the speedo. It was a little above the break pedal if memory serves me. Was real easy to do and you can retain the rubber gromet without leakage.
    Live Free or DIE!
  1. Right side O2 Sensor wiring/TOD wiring harness proper locations
    By CowboyErik in forum VX Troubleshooting...
    Last Post: 07/27/2013, 11:32 AM
  2. Rear fog and front fog lights wiring
    By David Wiltshire in forum Japanese Domestic Model (JDM) VXs
    Last Post: 07/07/2013, 01:40 AM
  3. How custom front bumpers should be done
    Last Post: 04/18/2010, 10:53 AM
  4. turn signals
    By rstevens24 in forum VX Troubleshooting...
    Last Post: 12/29/2004, 11:44 AM
  5. wiring for front speakers(help!!!)
    By valenki in forum VX Troubleshooting...
    Last Post: 10/11/2003, 06:48 PM
