Results 16 to 30 of 32
Thread: dash light mods
etlsport dash light mods 06/28/2006, 11:45 AM
LittleBeast fyi 06/28/2006, 08:03 PM
LittleBeast Oh yeah and if you really... 06/28/2006, 08:06 PM
Spike Modified dash pics - anyone... 06/29/2006, 04:30 AM
wintermute Resistor? 02/08/2013, 02:09 PM
hughesdt LED resistor 02/08/2013, 03:47 PM
wintermute Thank you for explaining.... 02/11/2013, 01:21 PM
UWVX89 I'm curious how much effort... 02/12/2013, 11:15 AM
tom4bren I assume that you've tried... 02/12/2013, 12:08 PM
etlsport The gauge cluster lights are... 02/13/2013, 05:19 AM
ABDragonVX Just for clarity, if I was... 02/13/2013, 11:58 AM
UWVX89 No haha the dimmer nob does... 02/13/2013, 12:42 PM
LittleBeast No the bulbs for the gauges... 02/13/2013, 10:39 PM
wintermute AWESOME info. Thank you. ... 02/13/2013, 10:47 PM
Mile High VX Is it the same bulb for the... 02/14/2013, 05:19 AM
LittleBeast The light in the instrument... 02/14/2013, 07:32 AM
ABDragonVX Thanks for the info 02/13/2013, 10:52 PM
LittleBeast Oh I also forgot to mention... 02/14/2013, 07:36 AM
wintermute Thanks to etlsport, the... 03/21/2013, 06:16 PM
wintermute Swapping out the LEDs in the... 03/21/2013, 06:25 PM
wintermute http://www.vehicross.info/gall... 03/21/2013, 06:33 PM
wintermute A better shot of the AC unit.... 03/21/2013, 06:46 PM
Jonnie Wow! 03/21/2013, 07:26 PM
whitebreadx I this the Web site you... 03/22/2013, 01:22 AM
wintermute Yeah, that's where I ordered... 03/22/2013, 10:30 AM
EVO That my friend is POPPING!!! ... 03/22/2013, 05:07 AM
whitebreadx Was it hard yo install the... 03/22/2013, 02:24 PM
wintermute Installing the dash mods... 03/26/2013, 11:27 AM
whitebreadx Oh and quick question how did... 03/22/2013, 02:26 PM
wintermute Thanks! Shifter is really... 03/26/2013, 11:32 AM
FenderBender WOW that is sweet. Nice job 03/22/2013, 07:25 PM
ipd Has anyone done a bulb swap... 12/15/2017, 08:30 PM
    2001, Ebony Black, 1153
    Is it the same bulb for the "light" that shows if the Cruise is on or the Heated Mirror or the Rear Defrost?
    The light in the instrument cluster (gauges) that shows if cruise control is on or off is a "74" sized bulb. In fact all those indicator (dummy lights) are 74 sized bulbs.
    The rear defrost bulb would be one of the "T" bulbs I provided the link for. You need to pull it out measure (in mm's) and compared with the detailed specs that V-LEDs provides.
    The only bulbs that I would suggest checking on would be the side view mirror adjustment bulb. If I am remembering correctly that one was hard to figure out, but then again it might just be a "T" bulb, but I know that the power/winter buttons will need a little custom fabrication. Looking back on that one I think you might be able to modify one of the sizes (probably the smallest one) of the "T" bulbs and mak it work. You will have to discard the screw in base and wrap the leads around the custom installation of the bulb of the winter/power button.
    BE VERY CAREFUL when you are disassembling the power/winter buttons as they are preloaded with a really small spring and ball bearing that will shoot out if you don't take your time.
    Feb 2013
    2001, Green, Vehicross, 0773
    Thanks for the info
    Oh I also forgot to mention that there is 2 bulbs inside each of these buttons/switches that illuminate when pressed. One is just a "T" bulb, and the other is one of those "T" bulbs but has a green rubber tip on it. So I used one blue for the general illumination of the button and one white for the "on" position.
    Feb 2010
    2000, Kaiser, VX, 0125
    Thanks to etlsport, the littlebeast, and hughesdt for the posts and advice on this one. Just wanted to post an update on my progress. I ended up swapping out every light in the cabin with blue LEDs with the exception of the door open cabin light which I swapped for a white LED. In the process since I had the console out, I ended up tackling the project to swap the gauge faces for the electroluminescent Trooper faces in silver. I'm pretty happy with the results.
    Feb 2010
    Swapping out the LEDs in the AC climate control unit was a bit of a pain, but I was able to remove the original green LEDs and replace with lovely blue new ones without too much of a hassle:
    And console in progress:
    Feb 2010
    Feb 2010
    A better shot of the AC unit. Button LEDs are a little too bright currently for my taste, so the next project is to change out the resistors to knock them down a little.
    Jun 2003
    1999 Victory Ironman 1703
    Wow!
    Aug 2011
    2000, firefox, base,
    I this the Web site you bought it from.
    http://www.makotoautotrends.com/chec...0vqsib30q69tm5
    whitebread
    Feb 2010
    Yeah, that's where I ordered these. They are one of the last places on earth I think that still has some in stock.
    I have been looking into custom printed EL gauges with a few different EL panel manufacturers and it seems achievable.
    Thanks for the kudos everyone. Would not have been possible without this forum.
    Quote Originally Posted by whitebreadx View Post
    Nov 2012
    1999, White Ironman Ed., 1707
    That my friend is POPPING!!! NOICE!
    Aug 2011
    Was it hard yo install the whole unit its self.... I had seen this a couple of mounth back but was too scared to attempt install
    Feb 2010
    Installing the dash mods actually wasn't that difficult at all. I was a little wary of tackling the job, but I read through all the posts I could find here and decided that it was very doable. I would say it just requires patience. The hardest parts for me were the actual trimming of the gauge set to fit the Trooper gauges into the VX console. It is a bit of trial and error trimming bits off with an x-acto blade and a straight edge, then checking the fit and placement. The EL material is very thick. It's like multiple layers of sheet plastic. The other hard part is just making sure not to break off the plastic tabs when disassembling and reassembling the dash.
    Aug 2011
    Oh and quick question how did you get your shifter like that... that is super nice
    Feb 2010
    Thanks! Shifter is really easy. Just remove the center console and the plastic shifter cover. Underneath the shifter bezel there is a light assembly mounted to the vertical wall of the shifter assembly that just twists out. You'll see the wire sticking out. This bulb can just simply be removed and replaced with the LED of your choice. It uses the T5 wedge.
  1. Oil dash light
    By Pepino in forum VX Troubleshooting...
    Last Post: 01/28/2008, 04:09 PM
  2. Dash Light outage
    By SPAZZ in forum VX Troubleshooting...
    Last Post: 12/31/2004, 12:28 AM
  3. Starting dash mods... am I nuts?!
    By coachreed in forum VX Modifications...
    Last Post: 08/26/2004, 09:54 AM
  4. e-brake light on dash
    By AlaskaVX in forum VX Troubleshooting...
    Last Post: 11/26/2003, 10:46 AM
  5. Different ideas for light mods
    By WyrreJ in forum VX Modifications...
    Last Post: 03/02/2003, 09:59 PM
