Trying to put some Bilstein shock on as part of my lift. The lower eye rubber bushing hole seems to be quite a bit smaller than the mounting lug on the axle.
I was going to try to alcohol it up and slip it on... If that doesnt work, Do they make larger I.D. diameter bushings? Any thoughts, suggestions or idea's would be appreciated.
