So the tabs for my passenger window broke off, and instead of throwing out a perfectly good piece of glass, I read the threads and I tried the quick-and-dirty fix, using JB Weld to fix my windows.
That didnt work that well.
NOT recommended, dont waste your time.
Then, I read in this forum about the fact that 3M has the right kind of glue available, but Isuzu doesnt sell replacement tabs: they only sell new pieces of glass with the tabs pre-glued on. The cheapest I could find new glass is from Merlin: he quoted me $170 (which includes shipping to California). The local dealership wanted about $250. Not bad, but Im cheap. Then, Merlin suggested that I go to the General Motors parts department and see if they have a similar tab.
After some talking and research with the
GM Parts guys, they found a part that looked right:
GM Part number 22689012
These cost $9.64 each, I bought 2.
Total cost of tabs: $20.88 (make sure you call ahead to see if they have them, I bought the last 2 that they had at my supplier). The screws that held the old tabs also fit this piece, so it seemed promising.
Then, I went on the 3m site and found a local supplier to get the 3M parts.
3M Automix, Channel Bonding & Sidelite Adhesive. Part# 08641: $13.75
3M Automix Applicator Gun. Part# 08191: $63.21
3M Mixing Nozzles Clear. Part# 08197: $18.54
They misquoted me when I called, so I got the gun for $40 instead of $60, so my
total cost of 3M parts was $87.36
On to installation.
-I removed the old tab
-Scraped off all the old glue/JB Weld
-Put the glass back in the door and marked the location of the tabs with a pen on the glass
-Loaded the gun
-filled the tab with glue, and stuck it on the glass.
-waited about 4 minutes, and it was dry (fast curing time)
-put the glass back in, and bolted it in place.
It works fine now, and has been for the past 2 days. We'll see how long it lasts, Ill post here if it breaks off again.
Total cost for repair: $108.24
some things I noticed:
-The new tab causes the window to not completely recess into the window.
About 1/4 inch of the window sticks out. Not a big deal to me, but worth noting.
-The 3m nozzles are one-time use, but the tube of adhesive cliams that if you close it back up, you can use it again later. (you get about 10 nozzles in a pack)
Reflections:
I would buy the tabs, take them to your local glass shop, see if they can just glue them on for me, and re-install it myself. $60 for the mixing gun and $18 for the nozzles is pretty steep if you ask me.
Well, there it is. hope that helps. Good luck!
