Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: roof rack EXTREMELY disconcerting
  1. #16
    Jun 2006
    2001, black, vehicross, 1234
    so, dismounted the roof rack (once i located my stashed security pin hex wrench) and removed the rubber endcap of the wingrack. i tilted the open end of the wingrack, and lo and behold, part "A" — the threaded plate nut — slid right out into my hands. brilliant. here's the new wrinkle: the machine bolt securing the wingrack to its footing had not — in fact — worked it's way loose, but instead had sheered off completely. nice. next step, removing that, and getting a machine bolt the right size and length to match part "A." my brainstorm was to remove one of the other assemblies, so i could bring that to the shop in pursuit of a match. i have to give some props here, and say that the mounting assembly is really straightforward, even if they did use some slightly "specialized" hardware (specifically, the threaded plate nut).
  2. #17
    Jun 2006
    6x20mm machine nut, 3/4" long. natch, they didn't have stainless, but i figure metal will work fine (not to mention the red locktite). so, it's up, it's on, and it's tight. thanks to all who helped.
  1. Yakima roof rack clearance with sliding roof?
    By JULIAN911 in forum Ldub's After Midnight Topics
    Last Post: 03/21/2014, 01:35 PM
  2. Want Roof Rack
    By disasterlady in forum VX Troubleshooting...
    Last Post: 01/05/2007, 04:28 PM
  3. roof rack
    By BOSSKE in forum VX Troubleshooting...
    Last Post: 07/04/2005, 02:12 PM
  4. Replies: 7
    Last Post: 06/09/2005, 02:39 PM
