Results 1 to 9 of 9
Thread: Questions about the brake/gas pedals
    Do NOT use the clamp on generic pedals. They move around and pose a hazard (they have all kinds of little bolt heads that can grab a shoelace, etc.
    I have switched the pedals on all of my manual transmission cars to some mid-range Sparco pedals. I can't remember the model, but they are available on eBay often, usually for less than $40. I like them because they have a little pad on the left side that makes heel-toe downwhifts easier.
    They install fairly easily; remove the existing rubber pad and use each pedal as a drill template. You might have to remove metal from the pedals if they have a larger footprint than you new pedals. I've never had to do this though.
    Here's a photo -these were in my S14.
    I had a silver (unpainted) set in my WRX.
    I still have stock pedals in the VX. I'm not doing any fancy footwork, so I haven't bothered to swap them out.
    May 2004
    99 Astral Silver w/ SC
    thanks for the info, Mbeach do you have any pics available? Just curious as to the look installed.
    "You can live your life in a thousand ways,
    but it all comes down to that single day,
    when you realize what you regret,
    but you cant relaim and you cant forget."
    ----Trans Siberian Orchestra
    beat me to it...
    i used clip on pedals.. havent had trouble with anything catching my shoe laces, but i covered the back of the clips with e-tape to make sure.. i did run into the problem of the stock brake pedal was too small so not all the clips fit, i had to put in little pieces around the pedal to make it 'wider' this also made is so when i wear my work boots my foot catches on the brake pedal sometimes (im a size 12)
  1. 2 gas pedals!
    By DOCSXV in forum VX Troubleshooting...
    Last Post: 03/01/2010, 08:54 PM
  2. Brake questions
    Last Post: 11/28/2009, 08:49 PM
  3. new pedals
    Last Post: 04/26/2007, 09:06 AM
  4. Accelorator/Brake Pedals
    Last Post: 02/07/2004, 05:42 PM
  5. Pedals (covers)
    Last Post: 11/15/2003, 07:10 AM
