Results 1 to 9 of 9
Thread: Questions about the brake/gas pedals
    May 2004
    99 Astral Silver w/ SC
    I have been considering adding the aftermarket pedals for the gas/brake however I have some concerns before buying them.
    1) Anyone have any high recommendations of ones they have used?
    2) The only ones I have seen up close are sold at Walmart/Auto stores and they look to just clamp on. Is this safe? And are there other methods of attaching them?
    3) Did you notice much difference is the leg spacing? I have noticed I have plenty of leg spacing, however it sacrifices my closeness to the radio controls, having to lean up to flip channels, which I do ALOT.
    4) Anyone have any pics of the one they have installed?
    Thanks
    ----Trans Siberian Orchestra
    2001, Proton Yellow, #0580
    I recommend these Razo's that I found on eBay - about $35 if memory servers. They really improve the feel and grip of my shoes on those pedals (the existing gas pedal is a joke).
    More info here: http://www.wildtoys.com/vehicross/VX...edalsAfter.asp
    -- John
    Do NOT use the clamp on generic pedals. They move around and pose a hazard (they have all kinds of little bolt heads that can grab a shoelace, etc.
    I have switched the pedals on all of my manual transmission cars to some mid-range Sparco pedals. I can't remember the model, but they are available on eBay often, usually for less than $40. I like them because they have a little pad on the left side that makes heel-toe downwhifts easier.
    They install fairly easily; remove the existing rubber pad and use each pedal as a drill template. You might have to remove metal from the pedals if they have a larger footprint than you new pedals. I've never had to do this though.
    Here's a photo -these were in my S14.
    I had a silver (unpainted) set in my WRX.
    I still have stock pedals in the VX. I'm not doing any fancy footwork, so I haven't bothered to swap them out.
    May 2004
    thanks for the info, Mbeach do you have any pics available? Just curious as to the look installed.
    beat me to it...
    i used clip on pedals.. havent had trouble with anything catching my shoe laces, but i covered the back of the clips with e-tape to make sure.. i did run into the problem of the stock brake pedal was too small so not all the clips fit, i had to put in little pieces around the pedal to make it 'wider' this also made is so when i wear my work boots my foot catches on the brake pedal sometimes (im a size 12)
    Here are some pedals that i sell, i powdercoat them to the color of your choice. The part i powdercoat is not the part your foot contacts so you will never wear off the powdercoat. I have the white set on My axiom and love them, They really improve the grip i have in the pedals and the feel. They are a little larger than stock but i did not notice any issues with leg spacing or hitting both pedals. The pedals are $45 shipped to the lower 48 powdercoated to your choice of color. They come with the clip on crap but i screwed mine on for good and that is what i advise anyone to do.
    Drive it like ya stole it!!!
    2002 Axiom XS
    -20" Eco 820s with Goodyears
    I use some that are made by the same company that morgan-tec uses, except mine are the "daimond plate" pattern.
    I've cut mine to a much smaller size (closer to stock) & like the man says...screws are the only way to go.
    I've found that small self drill/self tap that are just long enough work fine.
  1. 2 gas pedals!
    By DOCSXV in forum VX Troubleshooting...
    Last Post: 03/01/2010, 08:54 PM
  2. Brake questions
    By TexasProton in forum VX Troubleshooting...
    Last Post: 11/28/2009, 08:49 PM
  3. new pedals
    Last Post: 04/26/2007, 09:06 AM
  4. Accelorator/Brake Pedals
    Last Post: 02/07/2004, 05:42 PM
  5. Pedals (covers)
    Last Post: 11/15/2003, 07:10 AM
