Results 1 to 10 of 10
Thread: engine codes?
    1999 silver 1346
    engine codes?
    I went to autozone and am getting 2 codes PO400 and PO440?
    any ideas on what these might be?
    also if i reset the check engine light does anyone know how many miles it resets itself if i want to get an inspection. I was told that after i reset the light a inspection machine will know and wont pass me untill a certain amount of miles have gone by without the light.
    thanks
    adam
    2001, Proton Yellow, #0580
    It took my truck about a week before I could get the codes to qualify after a reset (it depends on the amount of driving you do and not the actual time) - same issue - I was pulling a code for a faulty battery and the reset disqualified me for passing the emissions test.
    -- John
    1999 silver 1346
    thats what i ment , how many miles will it reset?
    1999 silver 1346
    I was told one of the codes is a egr valve, does anyoine know whrere this is located and is it easy to change myself?
    P0400 Exhaust Gas Recirculation Flow Malfunction
    P0440 Evaporative Emission Control System Malfunction
    heres a link to a list of codes http://www.obdii.com/codes.html
    i dont know details about the EGR valve, but i remember a thread saying it wasnt terribly difficult to pull, but also that a lot of times you could just clean it out and it would be okay, do a search for EGR and youll probably return some good results
    1999 silver 1346
    anyone have any idea what this might be?
  1. engine codes P0327, P0161
    By pbkid in forum VX Talk...
    Last Post: 04/20/2009, 08:24 PM
  2. Long drives and engine codes....
    By Kenny in forum VX Talk...
    Last Post: 06/27/2007, 05:38 PM
  3. suggestions for engine P1404 and P0402 codes
    By bielsubob in forum VX Troubleshooting...
    Last Post: 01/03/2007, 02:20 PM
  4. Engine Codes?
    By colmhd in forum VX Troubleshooting...
    Last Post: 10/13/2005, 05:12 PM
  5. Check engine - Codes po171, po174, po303
    By Rapp in forum VX Troubleshooting...
    Last Post: 03/27/2005, 10:45 PM
