Results 1 to 9 of 9
Thread: Brembo Brake Retrofit for VX
    Dec 2003
    2000, Black, VehiCross, 0551
    Hi guys,
    I don't post too often but I have a question. It is time for a brake job and I will likely need rotors as well. Having come from the Porsche community, with their stellar brake performance (made by Brembo), and never having been happy with the braking ability of the VX.......the question is.......
    Is there a Brembo big brake upgrade available for the VX?? If not, are there any other big brake upgrade kits available??
    May 2004
    99 Astral Silver w/ SC
    I have not heard of a brembo setup for the vx. As for an upgrade I have the stainless lines on mine which everyone here says is a very good upgrade. I cant tell you how it was before & after because they were on when I bought it, but I am very happy with it now. The only thing I plan to really do is go with ceramic pads soon.
    ----Trans Siberian Orchestra
    2000, Black, VX, 0021
    HI,
    I had the same question and talked to a brembo rep I autocross with. He said it is possible to do but it will more than likely require a wheel with a different offset. At that point I decided it required no further investigation because cost of wheels and brakes would be over the top in my opinion.
    Anthony
    I've been all over any fixed caliper brake upgrade, and I haven't found any decent candidates.
    Of course you would have to make adapter brackets, to mount the calipers. This is not really a big deal if you've already found the rotors.
    The rotors are tough, because of the hubs' bolting to them. Custom hats would be an extraordinary expense, so no big rotors.
    The final nail in the coffin was caliper clearance. It really doesn't matter what offset you have, the wheels would have to have significantly dished spokes to clear any calipers larger than the stock floating units.
    Baer makes nice floating calipers (think Corvette), that don't require as much clearance, but you'd still be looking for some suitable rotors.
    I suppose that the VX brakes are fine for the kind of driving it was designed for. With some quality rotors, pads and maybe some SS lines it could get a little better.
    2001, Dragon Green, 1342
    I agree with mbeach on quality pads and rotors, but stainless steel lines are nothing more the rubber hoses with a steel mesh cover. Less chance of blowing or cutting one, but will have no effect on braking performance.
    Quote Originally Posted by rowhard
    Good quality SS lines (Goodridge or better) will be lined with Teflon. They will not deform under pressure, and they are abrasion resistant. Good ones will also have a Teflon coating on the outside.
    They do make a difference.
    Have someone step on your brake pedal while you hold one of your brake lines (reach through a wheel). You can actually feel the hose swell as pressure increases. This translates into a "spongy" feel at your foot.
    Tone,
    Can't you take the piston dimensions (diameter and o-ring groove) and find some nice replacement rings without going through Brembo?
    Stainless lines (flush your fluid if you haven't in a year or more) and performance pads are really all you need unless you are hard core racing or on the track. I would never go with Brembo again (they made the calipers on my ML55) as they refused to sell me new seal kits for the leaking ones I have but would sell me new calipers?
    If you want to paint your calipers, here is source where I shop and I can offer you pads a bit cheaper than they have them. I currently run EBC Red Stuff ceramic pads front and rear but beware, ceramics typically make more noise, especially during brake in. http://www.sfxperformance.com/search...ems&type_id=34
  1. I brake for ABS
    Last Post: 03/19/2013, 12:06 PM
  2. EBC brake pads and Apex brake lines
    Last Post: 12/14/2011, 02:15 PM
  3. Brake Light
    Last Post: 11/22/2009, 05:05 PM
  4. Brake
    By Mark B in forum VX Talk...
    Last Post: 06/02/2008, 06:08 AM
  5. using the e-brake
    By etlsport in forum Polls
    Last Post: 11/13/2007, 09:10 AM
